[phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 122: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 124: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 126: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 122: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 124: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 126: Invalid argument supplied for foreach() WorldWorksGames • View topic - new type of T clips (for added stability)
Post subject: new type of T clips (for added stability)
Posted: 09-15-2011, 11:17 AM
COG Joined: 05-31-2009, 07:35 AM Posts: 148
I don't know of a "better" way to explain this.
Often you have a multi-story build, with larger areas that fail to have the walls needed to support upper areas as well. An differnt type of T clip could work wonders.
These T clips are an I clip, with a perpendicular clip below them, but the clip is rotated 90 degrees from the Normal T clip (I.E. it still sticks up/down compared to the I clip, but the opening at the top of the clip runs along the I'clip long part.
Here you could put a 6" railing, wall, or something else, and the added stability helps keep the floors from sagging due to lack of support.
